Home Automation dimmer to variable DC interface
Subject Author Date
dimmer to variable DC interface B Fuhrmann 03-12-09
Posted by B Fuhrmann on March 12, 2009, 6:45 pm
Does anyone know of a reasonably simple circuit that can take a typical
dimmer output and create a DC output from 0 to 24 volts?
This would be used to drive a particular LED board that is designed for
24VDC, dims to almost off at 3VDC.
Bill Fuhrmann
Posted by Petem on March 13, 2009, 12:02 pm
message de groupe de discussion :
vfWdna62DZDuDSTUnZ2dnUVZ_tXinZ2d@posted.cpinternet...
Bill a light dimmer cant be used in such a way cause light dimmer dont
really dim the voltage level, it only chop part of the syn wave leaving only
a fraction of the total power passing in the load, creating the effect of
dimming an normal light..
What you need is a variable power supply, that can be set from 3 to 24 volt
dc..
but can you be more precise of what you want to acheive? cause I am not sure
of your goal, do you need a 24 volt source to be set at 3 volt permanently?
Similar ThreadsPosted
dimmer to variable DC interface March 12, 2009, 6:45 pm
Powerlink USB C Interface January 30, 2005, 7:29 pm
what wire between HAI Omnipro II and interface? February 14, 2007, 3:18 pm
UPB dimmer switch (must be light almond) August 7, 2005, 12:34 am
Singing light bulb on dimmer switch May 20, 2006, 3:22 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
