Hi I want to control occupancy sensor [PMS02] and motion sensor [MS14A] using powerlinc V2 controller USB [2414U]. There is also an RF transceiver present in the circuit. Manually i be able to control the x10 PRO modules using the motion sensor/transceiver combination. The lamp module is LM465. I want to control the motion sensor/occupancy sensor using PLC but no idea about how it can be done Can anyone suggest steps [if possible] Thanks Arnie
- posted
16 years ago
