Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by John J. Bengii on May 13, 2008, 8:43 am
Please log in for more thread options for generating random all lights on and other random on codes. | |||||||||||||||||||||||||
Posted by David White on May 13, 2008, 9:03 am
Please log in for more thread options transceiver but it never worked at all. So it sits in a box - should be in the garbage... John J. Bengii wrote: > Do you have X-10 wireless units in the house? The receivers are notorious
> for generating random all lights on and other random on codes. > >> Hello. I recently purchased and installed 2 XPS-3 switches I got off EBay.
>> One has a WS-14A/XPSS companion switch. >> >> Almost as soon as I installed these, I have noticed that the one with the >> companion switch will sometimes turn itself off. But in the last couple >> days, I have noticed that it is also sometimes turning itself ON. The unit >> without the companion switch is fine. >> >> I have a CM11A that does turn some modules on/off on timers. But the >> switches in question are NOT controlled that way. Even so, the strange >> events do no relate to the events that are programmed (not the same >> times). I am also very sure that no one else in the area has X-10 running >> (I live in a pretty rural environment). >> >> So: >> >> (a) Do the XPS-3 units commonly have this problem? >> >> (b) Does the presence of the companion switch make any difference? >> >> (c) Does this seem a manufacturing defect? >> >> (d) Could this be due to a wiring mistake on my end? >> >> Thanks. >
| Similar Threads | Posted |
| XPS-3 Strangeness | May 10, 2008, 12:01 pm |
XPS-3 Strangeness
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> So:
> Thanks.
