Home Automation X10 programming from PC
Subject Author Date
X10 programming from PC Geordie 09-12-06
Posted by Geordie on September 12, 2006, 11:19 am
I'm trying to control an X10 system through a CM12U (similar to CM11) via
the serial port, using my own software.
I know the software is correctly talking to the serial port (because I tried
it with a modem), but I'm having difficulty communicating with the CM12.
What I'm sending is 0x04 (Header) then 0x5E (to address unit G2) but I can't
get a Checksum back from the CM12.
Any thoughts? One thing I noticed in the "Interface Communication Protocol"
document at the end of section 3.1 is "This format is typical of all
transmissions between the PC and the interface with the difference being in
the first transmission from the PC." - but I couldn't find anything about
__what__ is different about the first transmission.
TIA,
Geordie
Posted by Robert Bonomi on September 12, 2006, 4:33 pm
>Hi,
The first possibility that comes to mind is that the CM12 might be DTE,
not DCE, and your cabling is wrong.
Try adding a null-modem.
Posted by Geordie on September 12, 2006, 7:58 pm
>>Hi,
>>tried
>>can't
>>Protocol"
>>in
Hi Robert,
Thanks for responding. I know from bitter experience that transposing DTE
and DCE can be a PITA to resolve, but I don't believe that's the problem -
my software communicates with a modem ok and, though I didn't mention it,
the CM12 responds to the ActiveHome software on the same port/cable.
Regards,
Geordie
Posted by Charles Sullivan on September 14, 2006, 12:14 am
On Tue, 12 Sep 2006 15:19:33 +0000, Geordie wrote:
> Hi,
> TIA,
> Geordie
Are you sending the two bytes in one transmission? Sending separately
usually doesn't work.
Try sending the single byte 0xEB and you should get the same byte echoed
back.
Posted by Geordie on September 15, 2006, 11:42 am
>> Hi,
>> tried
>> can't
>> Protocol"
>> in
>> TIA,
>> Geordie
> back.
Thanks to all for your suggestions - as it happens, the immediate problem
lay elsewhere, but they're worth knowing about as I develop my code.
My starting point in all of this was that my X-10 system was getting
unreliable, and got worse when I upgraded the controlling PC to XP - I put
the problems down to the ActiveHome software, so decided to write my own.
After thinking about the posted suggestions, and trying a few other things
out, I tried out Test Communications on ActiveHome's Tools menu - no
response from the CM12. Replaced the CM12 and everything works again!
That still leaves me disillusioned with the ActiveHome software - given that
the CM11/12 sends a checksum in response to each commend, why on earth
doesn't ActiveHome verify this and let the user know if there's a problem???
I'll continue with my own software, but without so much pressure!
Thanks again for the pointers,
Geordie
Similar ThreadsPosted
X10 programming from PC September 12, 2006, 11:19 am
Crestron Programming September 10, 2008, 5:49 am
Emerson SW375 Ceiling Fan Receiver Programming July 21, 2005, 10:06 pm
