Home Automation X10 / RF analyzer
Subject Author Date
X10 / RF analyzer Robin 09-21-08
Posted by Robin on September 21, 2008, 5:35 pm
Hullo alt.home.automation
(Feels a bit quiet in here, but hopefully someone will read this.)
I've been using X10 for about 6 months. It's, er, obtuse sometimes, but
pretty flexible - which I like. I tried and binned several control
programs and ended up writing my own. Which works well enough.
My post is about a problem I encountered today, which I'm very puzzled
about.
An MS13 (a PIR) on detecting motion will send an RF signal (at
433.92Mhz) to a TM13 (a transceiver which plugs into a regular power
socket). When the TM13 'hears' the RF broadcast, it broadcasts an X10
command over the power line. I have a CM12 (which plugs into a computer)
which can send and receive messages from the TM13 (and other X10 devices
plugged into the power).
This all works fine... except.
When I take this configuration to an outbuilding, something odd is
happening. The TM13 and the CM12 still communicate - so the X10 commands
are being sent over the power line. However, the RF signals from the
MS13 are being ignored.
I've tried the configuration with several units. It's not a single
broken part. It's something to do with the outbuilding, and doesn't
appear to be the power connection, so it must be the RF connection,
musn't it?
How can I test this? Do I need an RF analyzer? Any cheap options?
The configuration works fine in the main building.
Or it could be that the signal being sent from the outbuilding is being
lost. Could this be the case? Signal passes one way only? When I say
they can communicate, the CM12 can send on/off messages to the TM13, but
this doesn't prove the connection the other way. Hm.
Any advice appreciated, thanks & regards;
Robin
Similar ThreadsPosted
X10 / RF analyzer September 21, 2008, 5:35 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
