Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Manny Balfour on December 27, 2005, 8:07 pm
Please log in for more thread options Using X10 PowerLinc 1132CU with Smarthome Plus software. Devices are all generic Radio Shack type modules. ON and OFF commands work fine. Dimming is a problem. Very often the device will go to ON but not obey the dim command. I can do manual DIM through the software with multiple clicks and that works fine. As a timed event, the dim commands often fail. Signal strength is not an issue. Are there adjustments in the software package that I can make to help this? Manny Balfour Sayville, NY mbalfour@nospamieee.org | ||||||||||
| Similar Threads | Posted |
| X10 PowerLinc 1132CU Dimming Problem | December 27, 2005, 8:07 pm |
| Dimming CFL's | August 21, 2008, 7:30 pm |
| FS: INSTEON PowerLinc V2 Controller USB 2414U | May 24, 2008, 2:01 am |
| 6201 repeater problem | September 7, 2005, 5:43 pm |
| Problem with x-10 system that used to be stable | October 10, 2006, 6:31 pm |
| Problem With CM11A, ActiveHome 3.5 and Keyspan USB/Serial | January 7, 2007, 11:14 pm |
| Re: Problem With CM11A, ActiveHome 3.5 and Keyspan USB/Serial | January 7, 2007, 11:34 pm |
| Problem with Intermatic T107-30 Timer - Running Slow | December 16, 2006, 2:05 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
