Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Graven Water on July 1, 2008, 5:11 pm
Please log in for more thread options (switch that goes on when the humidity is above a certain level). And I'd like the furnace fan to go on when the dehumidifier does, to circulate the air in my house so it'll dehumidify my whole house. The dehumidifier has to have a manual control to do this, because the ones with electronic controls forget their settings when power goes off, or they have a capacitor so they remember the setting a short time. Am I right that this would be a simple thing to do? Can anyone describe to me how it could be done? I'd get an electrician to set it up, but I'd like to get an idea of how it would work. There are various dehumidistats around. Honeywell makes one that is wall-mounted and directly connected to the house wiring, also one that is an interrupt switch and plugs into a wall outlet. thanks Laura | ||||||||||
| Similar Threads | Posted |
| Want a portable dehumidifier to work with heater fan | July 1, 2008, 5:11 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 7:02 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 8:18 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 4, 2008, 1:40 pm |
| Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... | October 21, 2005, 12:50 pm |
| Leviton HCC4D-1TW controller does not work with RadioShack Lamp Module 61-3002 | October 26, 2004, 11:39 am |
| Does Power Line Carrier work during power outages? | March 23, 2005, 1:53 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
