Home Automation Recommendation for distributed IO
Subject Author Date
Recommendation for distributed IO wdoe999 02-09-07
Posted by on February 9, 2007, 7:40 pm
Hi - I'm looking for recommendations for inexpensive distributed IO
boards for home automation.
I'd like to monitor and control a few points around the house. I'm
thinking of remote IO boards that talk serially to a central control
board (or maybe just a central linux box). I've seen a few IO boards
here and there, with not too bad prices (around $50 US). However,
they tend to have a lot of IO per board. Is there something out there
that is even smaller and cheaper? Let's say 1 to 4 IO points per
board, connected in a daisy chain. Thanks.
Posted by AZ Woody on February 9, 2007, 9:28 pm
Check out the 1-wire stuff from Maxim. It can be done with only a usb
port on the server, and many (cheap) devices are availible for
monitoring/control...
The usb->1-wire device is ~$20, but you need to do some programming.
I'm currently controlling/monitoring about 20 points with this
See www dot eclipsehomeauto dot com
email me at homeauto at eclipsehomeauto dot com
Posted by sylvan butler on February 15, 2007, 4:16 pm
The 1-wire suggestion is good. Also see RS-485.
sdb
What's seen on your screen? http://pcscreenwatch.com
sdbuse1 on mailhost bigfoot.com
Similar ThreadsPosted
Recommendation for distributed IO February 9, 2007, 7:40 pm
Need Fax/Answering Machine Recommendation November 3, 2004, 4:30 pm
Recommendation needed: Monitor vacation home, detect outages August 21, 2005, 8:25 pm
