Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Graven Water on July 4, 2008, 1:40 pm
Please log in for more thread options connect the R and G terminals to turn on the fan. So the dehumidistat switch would connect the R and G terminals as well as turning on the dehumidifier. Also they told me that if there's central AC, there would have to be a relay to avoid feeding power to the AC. I don't have AC now but I might get it. Comments? Laura | |||||||||||||
Posted by ransley on July 4, 2008, 4:24 pm
Please log in for more thread options > have to be a relay to avoid feeding power to the AC. =A0I don't have AC n=
ow but I
> might get it. =A0
> > Comments? > > =A0Laura A waste of time, as I said to lower humidity maybe 20% 35% will heat up the house maybe 3-4f at maybe nearly the same electric cost as running whole house AC. Only if interior temps were near 68 would this idea make sense as if you lived in Oregon. But if you are warm now, you will get hot running dehumidifiers. | |||||||||||||
| Similar Threads | Posted |
| Want a portable dehumidifier to work with heater fan | July 1, 2008, 5:11 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 7:02 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 8:18 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 4, 2008, 1:40 pm |
| Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... | October 21, 2005, 12:50 pm |
| Leviton HCC4D-1TW controller does not work with RadioShack Lamp Module 61-3002 | October 26, 2004, 11:39 am |
| Does Power Line Carrier work during power outages? | March 23, 2005, 1:53 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> connect the R and G terminals to turn on the fan. =A0So the dehumidistat
> dehumidifier. =A0Also they told me that if there's central AC, there woul=
