Home Automation Re: Want a portable dehumidifier to work with heater fan
Subject Author Date
Re: Want a portable dehumidifier to work with heater fan Graven Water 07-01-08
Posted by Graven Water on July 1, 2008, 7:02 pm
I wrote:
> I want to run a portable dehumidifier with an external dehumidistat
> (switch that goes on when the humidity is above a certain level).
> And I'd like the furnace fan to go on when the dehumidifier does, to
> circulate the air in my house so it'll dehumidify my whole house.
> The dehumidifier has to have a manual control to do this
I mean a mechanical control. My tongue got tangled, or my virtual tongue,
my fingers.
Laura
> the ones with electronic controls forget their settings when power goes
> off, or they have a capacitor so they remember the setting a short time.
> Am I right that this would be a simple thing to do? Can anyone describe
> to me how it could be done? I'd get an electrician to set it up, but
> I'd like to get an idea of how it would work.
> There are various dehumidistats around. Honeywell makes one that is
> wall-mounted and directly connected to the house wiring, also one that
> ?is an interrupt switch and plugs into a wall outlet.
Posted by ransley on July 1, 2008, 7:51 pm
> > circulate the air in my house so it'll dehumidify =A0my whole house. =
=A0
> I mean a mechanical control. =A0My tongue got tangled, or my virtual tong=
ue,
> my fingers.
> Laura
> > off, or they have a capacitor so they remember the setting a short time=
> > Am I right that this would be a simple thing to do? =A0Can anyone descr=
ibe
> > to me how it could be done? =A0I'd get an electrician to set it up, but
> > There are various dehumidistats around. =A0Honeywell makes one that is
> > ?is an interrupt switch and plugs into a wall outlet. =A0- Hide quoted =
text -
> - Show quoted text -
Dehumidifiers creat heat, mine can raise basement temp 3f. Do you have
AC. It depends on size , tightness of house, humidity level and temp
of house. If its big leaky and humid you will need a big unit that may
cost as much to run as AC and heat your home 2-5 degrees.
Dehumidifiers are best when outside air is under maybe 65. You dont
need a humidistat outside, its the inside you are doing.
Similar ThreadsPosted
Want a portable dehumidifier to work with heater fan July 1, 2008, 5:11 pm
Re: Want a portable dehumidifier to work with heater fan July 1, 2008, 7:02 pm
Re: Want a portable dehumidifier to work with heater fan July 1, 2008, 8:18 pm
Re: Want a portable dehumidifier to work with heater fan July 4, 2008, 1:40 pm
Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... October 21, 2005, 12:50 pm
Leviton HCC4D-1TW controller does not work with RadioShack Lamp Module 61-3002 October 26, 2004, 11:39 am
Does Power Line Carrier work during power outages? March 23, 2005, 1:53 pm
