Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by David White on January 7, 2007, 11:14 pm
Please log in for more thread options Hello. On the 1st, I used the built-in COM port on my computer to reset the clock and timers on my X10 CM11A. I do this every year. I used version 3.5 of ActiveHome and all went well as usual. I recently purchased a Keyspan USB->Serial adapter and installed the
latest drivers. I have used it a little and so far it seems to work
fine. But tonite I tried it with ActiveHome. It seems to work at least to some extent. By this, I mean that the communications module seems to load/unload, that the communications test reports all is well, and that I can turn modules on/off. However, the set interface clock function seems to be having problems. It never seems to stop reading the time on the CM11A and no results are displayed. After checking the log from the Keyspan, I can see the command 0x8B is sent but it appears that the read never completes. After googling a bit I have seen that the 0x8B should return 16 bytes of data. However, I never see more than 12-14 returned. So I guess my question is: have others seen this? Any ideas/fixes? Thanks. | ||||||||||
| Similar Threads | Posted |
| Problem With CM11A, ActiveHome 3.5 and Keyspan USB/Serial | January 7, 2007, 11:14 pm |
| Re: Problem With CM11A, ActiveHome 3.5 and Keyspan USB/Serial | January 7, 2007, 11:34 pm |
| activehome pro | January 25, 2007, 8:03 pm |
| ActiveHome SW doesn't see Com Ports | January 11, 2005, 4:14 pm |
| Trouble with Activehome | March 27, 2005, 5:29 pm |
| Help using X10 ActiveHome with windows XP PX | August 5, 2006, 6:32 pm |
| Is Activehome a place to start? | December 28, 2004, 3:22 pm |
| 6201 repeater problem | September 7, 2005, 5:43 pm |
| Problem with x-10 system that used to be stable | October 10, 2006, 6:31 pm |
| X10 PowerLinc 1132CU Dimming Problem | December 27, 2005, 8:07 pm |
| Problem with Intermatic T107-30 Timer - Running Slow | December 16, 2006, 2:05 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
