Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by UCS308 on October 18, 2004, 11:46 pm
Please log in for more thread options front. I would then like a chime to sound when they are triggered, but I would like a different sound depending on which sensor was triggered. Is there away to do this? Thanks. | ||||||||||||||||
Posted by Dmitri(Cabling-Design.com on October 19, 2004, 5:22 pm
Please log in for more thread options > Is there away to do this?
> Thanks.
You could do something like that with a pair of X-10 motion detectors setup to trigger separate X10 Universal Modules. You'd have to hook separate chimes to the relay contacts. One other approach would be to simply use two separate X-10 chime modules, but the only ones I know of (X10 PRO brand) don't let you choose another melody, so they'll sound the same. -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - alt.home.automation - 2436 messages and counting! ##-----------------------------------------------## | ||||||||||||||||
| Similar Threads | Posted |
| Motion Sensor, Multi-tone chimes. | October 18, 2004, 11:46 pm |
| 3-way motion sensor switch | February 8, 2007, 11:36 am |
| control motion/occupancy sensor using PLC [2414U] | July 19, 2007, 6:43 am |
| LEV 6417 motion sensor & LEV HCA02-10E Coupler/Repeater | August 3, 2005, 2:53 am |
| Motion (or Infrared?) detectors for lights or electronics? | January 1, 2007, 3:09 pm |
| X-10 DS10A Door/Window Sensor | August 24, 2005, 10:06 am |
| Directional Driveway Sensor Choices? | December 7, 2006, 9:29 am |
| Wind sensor & Weather Station with display panel or touch screen panel | August 23, 2008, 11:22 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
