Home Automation Line out audio over phone cable?
Subject Author Date
Line out audio over phone cable? Michael Burr 03-19-08
Posted by Michael Burr on March 19, 2008, 1:52 am
Hi all,
I'm working on a whole house FM transmitter project and would like to
mount the xmitter in my cupola to get it good and high. So I need to get
the audio line out signal from my wiring closet up there.
I'm considering pulling pairs 3&4 off a twisted 4-pair phone cable and
using on one line from each for left and right channel, and combining the
remaining leads from each pair for ground. The run total run distance
would be approx 35'.
Has anyone done something similar? Any thoughts would be greatly
appreciated.
Thanks,
Michael
Posted by Robert L Bass on March 19, 2008, 8:28 am
"Michael Burr" wrote:
> Hi all,
> appreciated.
Michael,
There are several ways to accomplish what you want. One simple methods is to
send speaker level audio up to the cupola and reduce it there to line level
using an audio transformer. Another option is to use baluns at each end.
Third, you might be able to use the twisted pair cable as is for line level,
depending on how much and what kind of noise is present.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
Posted by Michael Burr on March 19, 2008, 12:28 pm
>> Hi all,
>> appreciated.
> Michael,
Thanks for your thoughts Robert. I thought I'd start with line-level and
work my way up to speaker level if signal quality becomes an issue.
My biggest concern right now is wanting a "sanity check" on the idea
regarding form and current - don't want to fry wires in the walls. As I
understand it - typical current between line-level devices is in the
very low ma range and my 24G solid copper wire can take at least 500 ma.
One end will be line-out from a PC sound card and the other the FM
transmitter. I haven't found specs on it input impedance, but it has
typical line-in and will accept even MP3 players as input.
Michael
Posted by Robert L Bass on March 19, 2008, 8:19 pm
OK, not to worry, Michael. You won't fry the wires with line level audio.
> As I understand it - typical current between line-level devices is in the
There shouldn't be a power issue with your plan. The only question is whether
you'll pick up noise. I'd try it using just the wire and see. Then if you
still need baluns you've lost nothing.
Regards,
Robert L Bass
Fax 941-870-3252
Posted by Ryan on April 18, 2008, 10:53 am
Hello All,
I can attest that you should have absolutely no problems. I am using a
75ft run of twisted pair to run line-level audio from a wireless video
receiver to a computer line input .. and it works perfectly fine .. it
is directly wired to the connectors on either end.
In my case , the bottle neck for quality is the video
receiver/transmitter setup , not the twisted pair- so keep that in mind.
If you do get noise .. maybe try attaching one each of the pair together
in different configurations (I did this without thinking). It is
possible that one of the configurations may help to attenuate the noise
while it travels across the wire.
>> and work my way up to speaker level if signal quality becomes an issue.
>> the very low ma range and my 24G solid copper wire can take at least
>> 500 ma. One end will be line-out from a PC sound card and the other
>> the FM transmitter. I haven't found specs on it input impedance, but
>> it has typical line-in and will accept even MP3 players as input.
> whether you'll pick up noise. I'd try it using just the wire and see.
> Then if you still need baluns you've lost nothing.
Similar ThreadsPosted
Line out audio over phone cable? March 19, 2008, 1:52 am
maximum length for audio cable? February 1, 2006, 4:54 pm
Power line bridge? December 1, 2005, 4:44 pm
Power line bridge January 15, 2007, 3:53 pm
"Technical' cable/wire October 21, 2004, 6:14 am
X10 CM12u Serial cable Help April 8, 2005, 11:34 pm
Bass Burglar Alarms: Line Card March 27, 2007, 11:09 am
Bass Burglar Alarms: Line Card March 27, 2007, 11:10 am
Bass Burglar Alarms: Line Card March 27, 2007, 11:11 am
x10 Yard lighting rnnng cable question August 2, 2006, 10:42 am
Audio/video run with Cat5e October 28, 2004, 7:40 pm
HELP Please - Need Audio Distribution to Televisions December 30, 2004, 11:13 pm
Graphic Five Whole House audio October 20, 2006, 1:21 pm
Digital Audio and Video Networks? February 9, 2007, 5:20 pm
IR for lights and phone? March 27, 2005, 5:29 pm
