Home Automation Leviton Gigamax 5e vs 5e+
Subject Author Date
Leviton Gigamax 5e vs 5e+ Bob McBob 11-21-05
Posted by Bob McBob on November 21, 2005, 8:12 pm
I'm wiring my house for gigabit ethernet and am planning on using the
Leviton QuickPort jacks. Is there any reason to buy the 5e+
(component-rated) instead of the cheaper 5e (channel-rated) plugs?
The price difference seems to be about 15%.
Thanks!
Posted by Spam Catcher on November 22, 2005, 8:21 pm
4ax.com:
Considering Gigabit ethernet runs fine over 5e - I'm not sure 5e+ is worth
the extra price.
It also depends on how many jacks you're wiring in your house and your
budget. If you're wiring 10 jacks - 15% isn't that much more to pay. But if
you're going to have 50 - 60 jacks... that's a different story : )
Stan Kee (spamhoneypot@rogers.com)
Similar ThreadsPosted
Leviton Gigamax 5e vs 5e+ November 21, 2005, 8:12 pm
Does Leviton Intellisense really help? November 8, 2004, 6:07 am
NEED Leviton 16383 in Almond January 25, 2005, 12:02 pm
Leviton Z-Wave Vizia RF and Elk M1G August 1, 2007, 1:13 pm
WGL V572AB transceiver vs. Leviton HCPRF-1TW October 25, 2004, 9:21 am
Leviton vs. X10.com decora light switches November 10, 2004, 10:53 am
Computer Control over Leviton Green Series Components August 4, 2007, 7:56 am
Leviton 6291 local switch bounce/chatter August 21, 2008, 5:57 am
Leviton HCC4D-1TW controller does not work with RadioShack Lamp Module 61-3002 October 26, 2004, 11:39 am
