Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by mike on August 21, 2008, 5:57 am
Please log in for more thread options I switched a lamp to CFL and had to replace my dimming wall switch with a leviton 6291 (relay) switch. I dug it out of the pile of old X-10 stuff, it's probably 20 years old. Remotely, the switch works perfectly. If I push the manual switch very deliberately, it works. If I tap it as quickly as I can manage, it works. But if you walk up and tap it at a normal rate, the relay clicks 3 or 4 times and ends up in a random state. I fear this is gonna do harm to my CFL inverters. Closest schematic I can find is this one: http://www.nysaes.cornell.edu/cc/staff/pool/homeauto/agc.html I'm tempted to put a cap and current limiting resistor across the switch. More peak current will help keep the switch contacts from corroding. Better schematic? Better idea? No, I'm not gonna go buy a new switch, I'm gonna fix this one if it kills me. mike | ||||||||||
| Similar Threads | Posted |
| Leviton 6291 local switch bounce/chatter | August 21, 2008, 5:57 am |
| Does Leviton Intellisense really help? | November 8, 2004, 6:07 am |
| Leviton Gigamax 5e vs 5e+ | November 21, 2005, 8:12 pm |
| NEED Leviton 16383 in Almond | January 25, 2005, 12:02 pm |
| Leviton Z-Wave Vizia RF and Elk M1G | August 1, 2007, 1:13 pm |
| WGL V572AB transceiver vs. Leviton HCPRF-1TW | October 25, 2004, 9:21 am |
| Leviton vs. X10.com decora light switches | November 10, 2004, 10:53 am |
| Computer Control over Leviton Green Series Components | August 4, 2007, 7:56 am |
| Leviton HCC4D-1TW controller does not work with RadioShack Lamp Module 61-3002 | October 26, 2004, 11:39 am |
| RF light switch | September 15, 2005, 2:33 am |
| gate switch | December 10, 2005, 10:59 pm |
| X-10 Switch Question | April 14, 2008, 10:11 pm |
| X10 switch control logic | February 16, 2005, 11:32 am |
| Beggginer 3-way switch question.... | September 22, 2005, 5:33 pm |
| 3-way motion sensor switch | February 8, 2007, 11:36 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
