Home Automation Keypad Linc 8 Help
Subject Author Date
Keypad Linc 8 Help sray3 01-28-05
Posted by sray3 on January 28, 2005, 3:13 pm
I recently had my electrician install keypad linc and do not know how to
program it.Are there any easy step by step instructions I can follow the
program the darned thing ?
Thank You. stay3
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
alt.home.automation - 371 messages and counting!
Posted by S Gibbons on January 28, 2005, 9:08 pm
Look at Home Control Assistant.
They offer a 30 day, try before you buy, I found it useful to program mine.
You will need a computer to powerline interface like the CM11.
> Thank You. stay3
Posted by AutomatedOutlet on February 10, 2005, 4:15 pm
I don't think that the last post addressed the question.
OK, there are a lot of things you can program into that keypad but here
are the basics.
1) Press the little set button on the top of the keypad until all LEDs
start to flash.
2) select the button you want to program by pressing it once.
3) That button will then be flashing. If you want to program an ON/OFF
on it, just transmit the proper code from and transmitter.
4) If you want to program it to send the same command each keypress,
hit that button one more time before transmitting the code.
There are a lot of other functions and scene commands you can program
into that keypad. There should have been a full set of instructions
that came with it. You can download them from Smarthome or call our
office and we'll mail you one.
AutomatedOutlet
AutomatedOutlet's Profile: http://www.hometechforum.com/member.php?userid=80
View this thread: http://www.hometechforum.com/showthread.php?t=7315
Similar ThreadsPosted
Keypad Linc 8 Help January 28, 2005, 3:13 pm
