Home Automation Installing an ELK M1 Gold
Subject Author Date
Installing an ELK M1 Gold garydidio 11-09-06
Posted by garydidio on November 9, 2006, 4:55 pm
All,
I am in the process of installing an Elk M1 Gold system in my house. It
looks awesome, but as it's my first installation. The basic system I am
installing consists of the following:
* M1 Gold with 16 onboard zones
* 16-zone expansion unit
* 2 Keypads, one with a weigand reader
* Thermostat/lighting/serial interface
* Ethernet interface
* Two-Way Listen-In Interface with 3 speaker/microphones
* RCS TR-40 communicating thermostats (qty 3)
* 4WTA-B Smoke detectors (qty 7)
* CO Detector
* Motion detectors (qty 6)
* Perimeter contacts (garage doors, windows, doors)
* Outside and inside temperature sensors
Each of the sensors, detectors, and contacts will have its own zone so I can
have flexibility in controlling the environment.
1. How exactly are the security contacts wired up with the EOL resistors? I
am using contacts that are closed when the door/window is closed. Should the
resistor be in parallel or series with the switch?
2. The smoke detectors I am using are iSeries 4WTA-B with an EOLR-1 relay
attached to each. Each smoke is on a separate zone so I can easily see which
detector has tripped. Is this a good approach? How do I get all detectors
to go off when one goes off?
3. I will be installing a supervised bell/siren in the main living quarters,
as well as a siren in the attic. Do I need anything else?
4. Can you think of anything else I should consider?
Thank you for your assistance!
Gary
Posted by news.comcast.net on November 9, 2006, 7:13 pm
1. Wire the sensors in series with the EOL resistors. In other words, the
circuit flows from the control panel thorough a resistor (which you place
right next to the sensor if it's a recessed magnetic door sensor or inside
the sensor if it's a motion or glass break detector). The circuit continues
through the resistor, through the sensor and back to the control panel.
2. Yes, that will work fine. Smoke detector asounders are fired byt
changing the polarity of the 12VDC which powers them. In order to make all
the smokes sound at once you need to install a "Reversing Relay" inside the
control panel and feed the power to the smoke detectors through the relay.
Here's an example of the relay (my website):
http://www.bassburglaralarms.com/product_8796_detailed.htm
3. If your home is set back from the road or if it's hard to see house
numbers from a passing patrolo panel, consider installing an ELK strobe on
the outside of the house, perhaps under the eaves.
4. Yes, lots but it would be easier to narrow it down if we chat by phone
first.
Regards,
Robert L Bass
Bass Home Electronics
Online DIY Alarm & Automation Store
941-866-1100
www.BassBurglarAlarms.com
> All,
> * CO Detector
> can
> I
> the
> which
> detectors
> quarters,
> Gary
Posted by garydidio via HomeKB.com on November 10, 2006, 9:37 am
Robert,
Thank you for the information. Upon further investigation with the
distributor of my Elk system, he advised I do not need to have all fire
detectors sounding when one goes off. I will be installing an echo
speaker/siren in the living space which will not only announce the alarm, but
can tell me exactly which zone has been tripped.
Regarding the EOL resistors, I am still a bit confused. If the resistors are
in series with the contact switch or motion detector, then it should not
matter where along the loop the resistor is placed. There will basically be
three states: closed when the switch is closed, open when the switch is open,
or shorted when the leads are somehow connected together. If someone cuts
the line, this will have the same effect as opening the door. Am I missing
something?
The outside strobe is a great idea, as my house is set in the woods back from
the main road a couple of hundred feet.
Thanks again!
Gary
>first.
>> All,
>[quoted text clipped - 41 lines]
>> Gary
Message posted via HomeKB.com
http://www.homekb.com/Uwe/Forums.aspx/home-auto/200611/1
Posted by garydidio via HomeKB.com on November 10, 2006, 11:55 am
All,
I thought I would share my home automation, security and whole-house audio
adventure with you. I have owned some property in Upstate NY in the
Adirondacks for quite some time, and am finally getting an opportunity to
build on it. The plans are to initially build a 3-bay garage with one high
bay for my camper and a one bedroom apartment on the second level as a second
home. This phase will be completed in another month. Eventually I will be
building a timberframe home overlooking the lake, but that will not be for a
while.
I wanted to post some pictures, but the system won't let me! :-(
Since this is a second home and I will not be there all the time, I thought
it a good idea to automate the house so I can manage and control it while I
am not there. I also wanted to load it up with the latest gadgets since I
want to enjoy the time I spend in the house when I am not mountaineering.
There are three major systems going into the house:
1. Whole house audio system using SpeakerCraft components
2. Network and telephone distribution system using Leviton
3. Home automation and security using the ELK M1 Gold system
Whole House Audio
I had initially designed a system using Leviton's audio components (I am a
fan of the Leviton line of products), but upon further investigation, decided
to go with SpeakerCraft. With the Speakercraft system, I have divided the
garage/apartment into 8 zones (high-bay garage, two bay garage, bathroom,
bedroom, kitchen, screen porch, deck, and patio). The living room will
contain a 5.1 surround sound system consisting of a 50" plasma TV, in-ceiling
speakers and an in-wall subwoofer to conserve space. I am working with an
audio subcontractor for this part of my adventure.
The system is composed of the following:
* MZC-88 Multi-Zone A/V Amplifier Controller -- This device has 8
independent zones, 2 built-in AM/FM tuners with 10 presets per zone, and a
whole host of other features
* MODE (Music On Demand Experience) Keypad -- Pretty slick device that
enables me to fully control the zone, including complete control of my iPods
and playlists
* Yamaha 5.1 A/V amplifier (which one, I have not decided as yet)
* AIM surround sound speakers
* I-Pod Interfaces
* 50" Panasonic Plasma TV
* Other keypads and speakers
Using this system, each zone in the house will have complete control of a
variety of sources for both audio and video. I have taken care to run CAT-5e
and coaxial cables from my media closet to various locations throughout the
structure so I can not only listen to and view, but each location can also
act as a source. My contractor kids me all the time that with the amount of
wire I have put in the structure, I am going to disrupt the Earth's magnetic
poles!
Network and Telephone Distribution
This system is fairly straightforward and is composed of the following:
* Two CAT-5e cables from my utility closet to each telephone/computer
location (one for telephone and one for computer)
* Leviton 42" SMC structured wiring cabinet
* 24-port telephone/CAT-5e structured wiring panel
* 2 100MPBS Ethernet switches (one for the first floor and one for the
second floor)
* Linksys router/firewall
* Satellite internet (which one, I do not know at this time)
I have also included provisions for integrating this syetm with the whole
house audio system and home automation/security system so my computers can be
integrated into the systems, providing complete control.
Home Automation and Security System
This is the system I am currently working on. It is based on the ELK M1 Gold
with all the whistles and bells, including:
* 32 input zones
* 2 kepads
* Weigand reader for codeless entry using a key FOB
* Two-way speaker/microphones
* Temperature sensors
* Smoke and CO detectors
* etc.
Using this system, I will be able to completely manage and monitor the house
from my primary location in Massachusetts.
Rather than deal with different types of wire and always thinking of future
expansion, I ran CAT-5e wire to all the detectors, devices, etc. I even
installed some PVC piping from the utility closet to the media closet and
attic for future expansion, including the implementation of outside cameras
that will be linked to the system so I can remotely view what is going on.
So, I don't really have any questions, but would appreciate everyone's
thoughts I what I am doing. Thanks in advance!
Gary
Posted by Robert L Bass on November 10, 2006, 5:52 pm
> All,
> while.
SpeakerCraft has a line of architectural (in-wall and in-ceiling) speakers
called Proficient Audio. They sound excellent and prices
are quite reasonable. I've sold hundreds of them. I used them in my previous
home and will be installing them throughout the new
place as soon as I'm back on my feet.
Good stuff.
Best in terms of bang/buck ratio.
> Whole House Audio
You may also want to take a look at Xantech's MRC88 (8 sources x 8 zones).
> and playlists
I used the Yamaha RXV-3000 for a couple of years but I wasn't happy with it's
performance. I recently picked up a Pioneer Elite HT
receiver. I like the sound and it's more flexible. It has multiple, assignable
component and digital video I/O ports which made
configuring all of my components much eqasier.
Again, give Proficient (SpeakerCraft) a listen.
> * I-Pod Interfaces
When we were looking for a plasma unit for our vecation home in Brazil, I looked
at a fair number of models. Our TV room there is
small so I selected a 42" model. The Panasonic models were among the best we
saw, but serrvice was an issue. Unfortunately, the
only brand that had local service was an off brand. The image is good but not
as fine as I'd like. Oh, well.
> poles!
Heh, heh, heh. Sounds like something I've done a few hundred times. :^)
> second floor)
> * 32 input zones
> * 2 kepads
> * etc.
Whereabouts in Mass are you? I used to live in Belmont about 40 years ago.
Sounds like you're pretty much on the right path. If you need help with any of
this, feel free to contact me.
Regards,
Robert L Bass
941-866-1100
4883 Fallcrest Circle
Sarasota · Florida · 34233
Similar ThreadsPosted
Installing an ELK M1 Gold November 9, 2006, 4:55 pm
question about Elk M1 Gold alarm system November 6, 2006, 12:52 pm
