Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by wkearney99 on November 12, 2004, 2:22 pm
Please log in for more thread options What hacks exist to allow other IR remotes to send RF to things like the base station Radio Shack uses on things like their 8-in-1 remotes (15-2117)? It'd be handy to be able to send signals through this base station and I'd be willing to hack up a remote or two to do it. I ask for several reasons, one is that RS has discontinued this product so it's hard to get spares. The other being it'd be nice to use some other gadets to push the signals (if at all possible). Alternatively I've got an X10 MouseRemote receiver if it's a matter of using something different RF-wise. Is it possible and who's got links? -Bill Kearney | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Dave Houston on November 12, 2004, 9:13 pm
Please log in for more thread options all 418MHz signals as IR. The FCC ID number on the remote or base station can be used to verify that it uses 418MHz. If it does, the most recent versions of the Pronto and Marantz remotes and several models of the Home Theater Master remotes can send 418MHz RF. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by wkearney99 on November 13, 2004, 7:44 pm
Please log in for more thread options > I'm not familiar with this specific model but most of these merely repeat
> all 418MHz signals as IR. > > The FCC ID number on the remote or base station can be used to verify that > it uses 418MHz. If it does, the most recent versions of the Pronto and > Marantz remotes and several models of the Home Theater Master remotes can > send 418MHz RF. Thanks Dave, that helps. The FCC ID on the remote is AA01502117. I'd search for it on fcc's site but it appears be offline (or too busy to answer). Hope your health is well and thanks again. -Bill Kearney | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Dave Houston on November 14, 2004, 4:26 am
>> all 418MHz signals as IR. >> >> The FCC ID number on the remote or base station can be used to verify that >> it uses 418MHz. If it does, the most recent versions of the Pronto and >> Marantz remotes and several models of the Home Theater Master remotes can >> send 418MHz RF. >
>Thanks Dave, that helps. The FCC ID on the remote is AA01502117. I'd >search for it on fcc's site but it appears be offline (or too busy to >answer). It's fairly simple to add RF to most IR remotes. The 4-pin RF transmitter modules shown at http://www.mbx-usa.com/modules.htm need +5V, GND & DATA. The IR signal is usually sufficient although range is less than optimal because the RF transmitter is operating at the IR carrier duty cycle. The transmitter turn on/off time is less than 1 µs and the pulses in a 40kHz IR carrier are ~12.5µs at 50% duty cycle. You can filter the carrier but that will usually reduce the amplitude and you'll need to amplify it to trigger the RF transmitter. The upper portion of the circuit shown at http://www.mbx-usa.com/ocelot2rf.htm will work for this. Most RF receivers will not turn off so fast so they will output the DATA signal w/o the 40kHz pulses. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by wkearney99 on December 15, 2004, 11:07 pm
Please log in for more thread options Curious, I also looked up the Hughes remote I have for a DirecTV receiver
( OZ5HNS1026824 ). Apparently it uses 418 Mhz, which is what the Pronto units use as well, isn't it? I wonder what sort of signal it's 'shark fin' antenna puts out? The schematic for which is: https://gullfoss2.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=103912&native_or_pdf=pdf There are 18 (out of over 400) 418MHz devices from X10. With part numbers beginning with B4S. Don't know what they are. So it would seem the devices I've got are all on 430MHz. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Hack RF into remotes? | November 12, 2004, 2:22 pm |
| Waterproof remotes? | November 12, 2004, 2:23 pm |
| multiple remotes on a garage door opener with rolling code | December 18, 2006, 8:29 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>-Bill Kearney
