Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by ... on December 23, 2008, 6:34 pm
I would like to disable local access/changes to an HAI Omnistat RC-80 thermostat. Physical location is 2nd story. Thermostat will only be used to monitor current/outside temp. Temperature changes/adjustments to be made via console control keypads. I have teenage son that enjoys raising temperature to roasting levels in morning while other members suffer. I believe there used to be a technical bulletin or application note on removing or adding a jumper to board, but can not find when I could use it. Anyone have this helpful info or where located? Home Automation Industries HAI Omnistat RC-80 Thermostat: Single Stage, Heat/Cool, non-lighted version HAI - R80 Thermostat- How do you disable buttons? Best Regards, Toasty | ||||||||||
Posted by D on December 23, 2008, 8:47 pm
Please log in for more thread options Look at www.homeauto.com on the net | ||||||||||
| Similar Threads | Posted |
| HAI - RC80 Thermostat- How do you disable buttons? | December 23, 2008, 6:34 pm |
| networked thermostat? | October 20, 2004, 12:46 pm |
| is there a thermostat with dial in and wan ? | November 1, 2004, 10:33 am |
| RC-80B Thermostat Issue! | November 28, 2005, 10:03 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Best Regards,
> Toasty
