Home Automation Does a home power meter-base exist which uses BlueTooth?
Subject Author Date
Does a home power meter-base exist which uses BlueTooth? Jack Edin 12-29-05
Posted by Jack Edin on December 29, 2005, 5:38 am
Hello again,
I was thinking about replacing my home's meter base.
If I got a fancy enough one, I could monitor it in real time.
All of the ones I've ever seen have a serial port.
Not convenient to run wires out to my meter, to begin with. The serial
isn't perfect for long runs, but I can make due...
I don't have a PC near the meter...
But if I could get a wireless meter base, using BlueTooth or perhaps
802.11b with encryption...
Then I'd be happy.
These things are EXPENSIVE. May as well get what I can use.
Running wires ain't cheap... And this way I can move the PC within the
house, without having to change any meter-base's wire's endpoint...
So anybody know of anything?
Dave Houston?
Thankx, in advance...
Jack
Posted by RF Dude on January 1, 2006, 11:48 pm
Generally, you won't change the meter base. Add a current bridge to the
main load panel, or an external means of reading the disk turning on your
meter. Here are a couple of examples:
http://www.theenergydetective.com/
http://www.bluelineinnovations.com/
Good Luck.
Posted by ChainSmoker on January 3, 2006, 9:29 pm
> Good Luck.
Have you by chance tried either one of these? Your thoughts on the using
with a home automation system....
Posted by Jack Edin on January 4, 2006, 1:12 pm
Thanks for the tip...
I've visited both companies websites.
I've filled-out the need more info forms on both.
That was two days ago.
I've received a reply from TED. And
Good news... TED is on sale!!
Bad news is TED won't have a computer interface till summer...
Good news, maybe, is they're looking at Zigby for their wireless.
Blueline's product is already wireless, but just for the display - as
far as I know.
They have yet to reply to my questions...
Yesterday I asked an engineer at the local power company for advise. I
also asked him to look at TED, and he said "Certainly, the price is
right, if it works."
The power company uses electronic meters in some homes. When I inquired
about those he went on to say, (on this subject):
"It depends on the purpose of monitoring. The PGE meter collects the
consumption without regard to instantaneous usages, since there are no
demand charges in residential. Individual end-use monitoring is used to
check the usage of a specific load. Seeing the total meter
instantaneous kW is an accumulation of everything that is on in the
house at that instant. Since you are billed by consumption, it's kW
times time, so it's all those instantaneous kW's and all those
instantaneous times."
He gave me the number of their residential metering expert, but I have
yet to find the time to call...
I also received TED's manual. I need to look at the current
transformer's hookup instructions to see how I feel about hooking this
up myself.
Jack
>> the main load panel, or an external means of reading the disk turning
>> on your meter. Here are a couple of examples:
>> Good Luck.
Posted by Dave Houston on January 4, 2006, 10:11 pm
The Blueline method is one that has been used in DIY setups for a few years
(although not wirelessly). It has the advantage of reading the power
company's meter disc revolutions so it will agree with their readings. It
also has the advantage that it does not require an electrician to install.
The other one requires an electrician to install it. Without additional
technical details I would be leery of its accuracy.
In either case I would want a serial interface so I could access the data
from my HA system.
>far as I know.
>up myself.
>Jack
>>> Good Luck.
Similar ThreadsPosted
Does a home power meter-base exist which uses BlueTooth? December 29, 2005, 5:38 am
Does Power Line Carrier work during power outages? March 23, 2005, 1:53 pm
x10 power consumpsion April 4, 2006, 5:23 am
Power line bridge? December 1, 2005, 4:44 pm
Power line bridge January 15, 2007, 3:53 pm
PR: Power supplies at www.BassBurglarAlarms.com May 8, 2007, 10:53 am
Restore State after Power Failure? November 10, 2004, 12:54 am
How to do fixed wiring of X10 power at 110V? January 1, 2006, 9:08 pm
Computer-Controlled Power Outlet June 8, 2006, 5:09 pm
Contact closure of 120V power outlet October 13, 2005, 9:26 pm
X10 software to monitor and power cycle network devices May 6, 2006, 8:33 am
Power Button -start/stop desktop applications and external hardware in one click January 22, 2007, 10:12 am
Public posting home automation/home entertainment weblog February 13, 2005, 9:40 pm
INSTEON Lights Up Best Buy For Business ConnectedLife.Home Home Automation and Entertainment Bundle: View Best Buy ... (PRWeb via Yahoo! News) February 9, 2007, 2:02 am
INSTEON Lights Up Best Buy For Business ConnectedLife.Home Home Automation and Entertainment Bundle: View Best Buy ... (PRWeb via Yahoo! News) February 11, 2007, 2:02 am
