Home Automation DVD hookup up with Multiple TVs
Subject Author Date
DVD hookup up with Multiple TVs Mark Friesen 01-08-05
Posted by Mark Friesen on January 8, 2005, 9:30 am
Does anyone know of a DVR system that can be hooked up to several
televisions so that anyone of those televisions can utilize stored videos?
What I'm actually seeking is a distributed t.v. system that run's off one
DVR or computer that can access a DVD changer so it can select from a
library of say 100 DVDs (or more) and play back any movie that is request to
whatever television it is requested on throughout my house. I'm not
familiar with current trends and this may sound more like a fantasy, but if
cars can have CD changers, why can't homes have DVD changers?
Posted by Dennis Slater on January 8, 2005, 2:43 am
I have been studying this issue for some time. One of the best
solutions I have seen can be found on <A
href="http://crossbarmedia.com/.">Cross Bar Media</a>.
Posted by Mark Friesen on January 8, 2005, 11:03 pm
Dennis, This looks close to what I was looking for..many thanks! Are you
aware of any DVD changers or entertainment devices that can store a lot of
movies, preferably on DVDs or just maybe something maxed out like a
multi-gigabyte computer???
>I have been studying this issue for some time. One of the best solutions I
>have seen can be found on <A href="http://crossbarmedia.com/.">Cross Bar
>Media</a>.
Posted by wkearney99 on January 8, 2005, 6:34 pm
you
Bear in mind that a PC with enough disk space, CPU and the video output
cards may well cost CONSIDERABLY more than what just adding more standalone
DVD players might cost. That and if a DVD player breaks it's pretty cheap
and easy to replace. If the PC craps out you're really screwed. This isn't
to say using a PC server device is a bad idea; I do it here. Just that for
many consumers it might be a lot more work than they expect.
Think about it some. A cheapie DVD player can be had for around $50. It
makes little or no noise and has few critical components in it. A PC with
mutiple video cards (a pain in the ass to even configure) has quite a few
more critical parts, generally tends to make a lot more noise, consumes a
shitload of electric and is a lot more expensive to repair in the event of
failure. The noise can be mitigated by spending more on cases, fans and
cooling gizmos. But the cost to repair and tedium of getting it all
configured is NOT trivial. At some point it may well become trivial but
that time isn't quite here yet.
-Bill Kearney
Posted by wkearney99 on January 8, 2005, 6:28 pm
to
if
You can. Just be prepared to pay a lot of money for it.
What you can do with *any* video device is push the signal out onto channel
3 and use an RF amplifier to send it to as many TVs in the house as you
like. Those amps are generally under $50. There's distributed video. Then
add remotes that use RF signals to control the device from anywhere in the
house. Either using plain IR remotes and IR-to-RF repeaters or RF remotes
and an RF-IR base station. These repeaters are generally also around $50
each.
Just as you can take the channel 3/4 signal and amplify it you can also get
additional RF modulators that will let you put other video devices onto
other RF channels. Put the Tivo on channel 3, DVD on channel 30, VCR on
channel 40, etc. These RF modulators are generally about $75 per channel
and can be had in single, 2, 4 and even 8 sources. This lets any TV in the
house watch any of the sources. You could add as many modulators and
sources as your budget allows.
This is RF channel quality. Since you're going directly from video devices
into an RF amplifier it's going to look as good as any other perfectly tuned
TV signal. The audio is likewise going to be as good but you may want to
consider stereo RF modulators (and these cost more). It's not home theatre
surround sound but it's as good as most folks would likely need. Drive the
home theatre or main TV watching area with s-video and surround sound. Let
everything else just use RF channels.
The downside is that if you want to watch different things simulatneously
you need to have different devices. If you wanted to watch different DVDs
on each TV then you'd have to install more than one DVD player. There are
DVD changers that will *hold* multiple DVDs in a carousel but they generally
only PLAY one of them at a time. But if you're OK with manually putting a
DVD into a player then it's a reasonably cheap way to go about it, just add
a DVD player and an RF modulator, tune the TV to the right channel and have
at it. Just make sure your remote can control more than one player and that
if they're from the same vendor that they can be selected independently.
Sometimes it's better to get players from different vendors just to avoid
the trouble. As in, two DVD players from company X each see the same remote
signal and think it's for them. Versus two DVD platers from different
companies each with their own format of IR remote signals. There are ways
to setup IR distribution networks that work around this but prepare for
spending a lot more.
You could certainly make use of a PC with multiple video output cards to act
as the sources. Trouble is you'd need a pretty powerful PC with a lot of
disk space to handle more than a few DVDs. Either as movies copied on the
the hard drive or as multiple DVD-ROM drives. You're still faced with the
question of how to distribute the signals to the rooms as well as how to
control it remotely.
Bottom line is that for every signal you want to watch you've got to have a
source for it. From either individual video devices or multiple video
output cards. And then as a direct video connections via some sort of
multiplexer (ie Crestron) or as modulated RF channels.
-Bill Kearney
Similar ThreadsPosted
DVD hookup up with Multiple TVs January 8, 2005, 9:30 am
multiple remotes on a garage door opener with rolling code December 18, 2006, 8:29 pm
