Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by David White on May 17, 2008, 5:48 pm
Please log in for more thread options My computer is connected to the CM11A and the communications routines are running. But I when a macro I have downloaded into the CM11A goes off, I do not see anything in the communications log. I do, however, see the results of the macro being run. Is this expected behavior? Thanks. | ||||||||||||||||
Posted by BruceR on May 17, 2008, 8:22 pm
Please log in for more thread options housecode. David White wrote: | ||||||||||||||||
Posted by David White on May 17, 2008, 10:26 pm
Please log in for more thread options As always, thanks for the response, Bruce. That was a good guess. But
alas, both the house code on the Tools menu and the Monitored Housed Code on the Config menu are both set to the same code as are the devices that are going on/off. I can see the activity when I turn the device on/off from inside Active Home or from a mini controller. So it seems odd that I do not see them when the CM11A generates them when running a macro. BruceR wrote: > Make sure that in the configuration menu you are monitoring the correct
> housecode. > > David White wrote: >> Still somewhat of a newbie... I am using ActiveHome 1.42 with my
>> CM11A. My computer is connected to the CM11A and the communications >> routines are running. But I when a macro I have downloaded into the >> CM11A goes off, I do not see anything in the communications log. I >> do, however, see the results of the macro being run. Is this expected >> behavior? Thanks. >
Posted by BruceR on May 18, 2008, 2:29 am
Please log in for more thread options That does seem strange but the CM11a is a pretty limited device and I
haven't used one in years so I don't remember how it worked when I had one. David White wrote: > As always, thanks for the response, Bruce. That was a good guess. But
> alas, both the house code on the Tools menu and the Monitored Housed > Code on the Config menu are both set to the same code as are the > devices that are going on/off. I can see the activity when I turn the > device on/off from inside Active Home or from a mini controller. So > it seems odd that I do not see them when the CM11A generates them > when running a macro. > > BruceR wrote: >> Make sure that in the configuration menu you are monitoring the
>> correct housecode. >> >> David White wrote: >>> Still somewhat of a newbie... I am using ActiveHome 1.42 with my
>>> CM11A. My computer is connected to the CM11A and the communications >>> routines are running. But I when a macro I have downloaded into the >>> CM11A goes off, I do not see anything in the communications log. I >>> do, however, see the results of the macro being run. Is this >>> expected behavior? Thanks. | ||||||||||||||||
Posted by MarcB on May 18, 2008, 8:05 am
Please log in for more thread options David White wrote:
> Still somewhat of a newbie... I am using ActiveHome 1.42 with my CM11A.
> My computer is connected to the CM11A and the communications routines > are running. But I when a macro I have downloaded into the CM11A goes > off, I do not see anything in the communications log. I do, however, see > the results of the macro being run. Is this expected behavior? Thanks. I think that is the essence of a macro. you load it in the CM11 device, and it takes care of it without further action of your PC. You load a number of timed actions in the little box, you switch off your PC and let the thing do what you asked it to do. Note that this is only my interpretation of what I read in the manual, I could very well be wrong as I just bought the thing and I am trying to get it working in Linux. -- MarcB | ||||||||||||||||
| Similar Threads | Posted |
| Active Home Question | May 17, 2008, 5:48 pm |
| Older Active Home (v 1.3) / DST Question | February 26, 2007, 1:35 pm |
| Active Home & X-10 | April 3, 2006, 9:08 am |
| X-10 Active Home? | May 14, 2008, 1:50 pm |
| SmartHome vs. Active Home | February 6, 2005, 10:56 pm |
| newbie question : recommended exhibitions for home automation ??? | July 22, 2005, 1:23 pm |
| Illiterate X-10 Question | October 25, 2005, 6:39 pm |
| 4 camera DVR question | April 20, 2006, 9:54 am |
| X-10 Switch Question | April 14, 2008, 10:11 pm |
| Zwave wiring question.. | December 19, 2004, 9:44 pm |
| Wide Open Question(s) | January 24, 2005, 12:22 am |
| x10 basics--noob question | June 13, 2005, 5:00 am |
| Beggginer 3-way switch question.... | September 22, 2005, 5:33 pm |
| Wiring question: POE Interference | December 15, 2005, 9:13 am |
| Insteon/X10 USB controller question | January 17, 2007, 8:37 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> behavior? Thanks.
