Home Automation 6201 repeater problem
Subject Author Date
6201 repeater problem Harry 09-07-05
---> Re: 6201 repeater problem AutomatedOutlet...09-13-05
Posted by Harry on September 7, 2005, 5:43 pm
I had to replace a Leviton 6201 several months ago as it had failed
(power supply burned up). I replaced it with the new Leviton HCA-02-10e
and had nothing but problems with "ping pong" repeating, dimming issues
and errors. I found and purchased 3 of the old 6201 units, 1 to replace
the HCA-02-10e, 1 for the garage and a spare. After installing the unit
it worked perfectly for a day and then I noticed units not responding.
I tested the signal with Smarthome Testerlinc and found that there were
many errors being transmitted and the signal was in the 60's. The LED
was not flashng on the 6201. I replaced the 1st 6201 with another one
and found the same problem. So I replaced it with the last NEW on I
have and had the same result. Thinking that having 3 new units
defective was slim, I experminted a bit and found that if I applied
power only to the red wire it boosted the signal to 120-140 (with no
errors) on that phase only and flashed the LED. As soon as I applied
power to the black lead the unit stopped woking (no LED and many
errors). I connected the HCA-02-10e back up again and it works except
for the "ping pong" problem. Note that I powered up the 6201 in the
proper sequence and the white lead is to neutral and I disconnected the
known signal absorbing devices. There are no other transmitters or
repeaters installed and the system is controlled by a PC and CM11a.
What are the odds of having 3 defective (new and never connected) units
Thanks for any suggestions!
I posted this message in another group but only received one response..
Sorry if I repeat myself.
Harry
Posted by AutomatedOutlet.com on September 13, 2005, 11:33 am
Are you saying that you have more than one coupler/repeater installed?
If so, that's your problem. You should only need to install one of
them.
Martin
www.AutomatedOutlet.com
Posted by Harry on September 14, 2005, 5:54 pm
No,
I purchase 3 new units and after installing them 1 unit at the time
they all had the problem described abouve. There was only 1 installed.
I guess my point was that I have the same problem no matter which unit
i tried and the new version Leviton works fine except for the "ping
pong". Do I have 3 new defective Leviton 6201 units> Don't know how to
test them.....
Harry
Posted by Stanley Barthfarkle on September 21, 2005, 9:50 pm
Are you sure you're hooking it up to 2 separate phases?
> No,
> test them.....
> Harry
Similar ThreadsPosted
6201 repeater problem September 7, 2005, 5:43 pm
x10 couple/repeater September 11, 2006, 12:00 am
LEV 6417 motion sensor & LEV HCA02-10E Coupler/Repeater August 3, 2005, 2:53 am
Problem with x-10 system that used to be stable October 10, 2006, 6:31 pm
X10 PowerLinc 1132CU Dimming Problem December 27, 2005, 8:07 pm
Problem With CM11A, ActiveHome 3.5 and Keyspan USB/Serial January 7, 2007, 11:14 pm
Re: Problem With CM11A, ActiveHome 3.5 and Keyspan USB/Serial January 7, 2007, 11:34 pm
Problem with Intermatic T107-30 Timer - Running Slow December 16, 2006, 2:05 pm
